Mod/Con Runtimes
Heat_n_CT
Member Posts: 64
So now that it seems winter is finally here can we get some dialogue started with people that have mod/con boilers about what their Design Day temp, Sq Ft & BTU required, ODR set points, water temps, cycles per hr or day, and boiler run time and burner modulation percentage? Or anything else they'd like to add.
Just curious to see what I have to look forward to.
SWEI has the best way to dial in your outdoor reset. Crank the thermostat up and let it run. Fine tune your set points and when the house is comfortable, the boiler is putting out just enough btus based on outdoor temperature. He will probably elaborate on this for you.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
