CLR ok
unclejohn
Member Posts: 1,833
Is CLR spray cleaner ok to clean copper tube boilers like Lochnivar and others.
the outside of the coils? A mild acid work well on copper, just be sure to rinse well. Some acid based cleaners come with a neutralizer packet to use after the acid wash.Bob "hot rod" Rohr
Living the hydronic dream0 -
Thanks HR. I just used simple green. Turned out it was a single row of coil. Just sprayed it on and hosed it off. CO down to 26 when done.0
- 114 Geothermal
