Electric boiler
Wayco Wayne_2
Member Posts: 2,479
I'm in need of an electric boiler for some plant warming tables. I'm thinking 16 KW and modulating. I've never needed one before so I have nothing researched. Who has used them and what do you recommend.
I've used Thermolec with good success on several projects. If you don't need ODR for this application, Electro has some lower cost options (and one series, the EB-MO) with ODR.0
Agreed the Thermolec out of Canada, or the Electro MN from Minnesota are both excellent, small boilers. Argo is another common brand.
I believe the cast boiler guys still build cast and steel electric, wall hung. Burnham, SlantFin, Weil, and EFM (Electric Furnace Man) one of the oldest manufacturers around.Bob "hot rod" Rohr
Living the hydronic dream0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 891 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
