WIFI thermostat / humidity sensor recommendation? Honeywell preferred.
Dsisson
Member Posts: 116
I'm an architect. I have a client who needs a room where we need to monitor the indoor temperature and humidity level. We do not need to log the information, but the client needs to be able to access the temp/humidity remotely through the web & also get email/text alerts if the temp and humidity go outside predetermined levels.
I am familiar with the Honeywell wifi app for temp control, and it'd work great for this application, but I don't know which thermostat can also measure indoor humidity.
Can anyone make a recommendation? Thank you in advance!
Check out Wireless Sensor Tags http://wirelesstag.net/
I just setup a location with several tags. Does temperature and humifity. IFTTT compatible. You can setup all sorts of alerts. Pretty economical too.0 -
thanks guys, I"m looking into the wireless sensor tags. This looks like the ticket - the owner can monitor heat and humidity, and even have it turn on a small humidifier if necessary.0
