Viessmann Trimatik Control
rsv101
Member Posts: 14
Hello everyone. I have a viessmann VBC-22 boiler with a Trimatik MC controller. The previous owner has it hooked up to run only the domestic hot water with the Trimatik MC controller. Is the trimatik capable of controlling a heating zone like a thermostat would? I would like to heat my baseboard hot water heating zone with the trimatik so when i am calling for domestic hot water it becomes priority. They way it is currently set up is the baseboard hot water zone is controlled by a zone circ and thermostat hooked to a zone control board. The viessmann control wiring board has a spot for pump A and pump B, i am assuming i could wire the baseboard zone to pump A or pump B but what is going to tell the trimatik MC that i want the room temp at 72 degrees? Also does anyone know if the Remote Control is available for the Trimatik MC because i do not have one. Thank you for any insights.
