2 pipe system with bucket trap, F & T trap no main vents DROPPED HEADER QUESTION
Questions: A. would it be OK to have the bottom of the dropped header 26" above the water line instead of the 24" recommended height?
B. Can I instead drop the header to a point just above the top of the boiler?
C. There are no vents after the traps on the dry return lines, should I add vents?
Thanks to all.
If you are doing a dropped header the minimum height from the manufacturer doesn't really matter anymore. You need to be above the water line for sure. The more drop you do the more piping options you can have because it give you space. If you want it just above the top of the boiler I don't see that being an issue. I have mine like that and I have seen others do the same. Not sure what the jacket on your boiler is like, but if you need to remove the to panel for any reason keep that in mind with the drop header. On my boiler I made sure to keep the header out in front of the boiler so I could later access the block for cleaning later (mine is through the top). The important part is the height of that first riser and at 3' you should be in excellent shape. I default to someone with 2 pipe experience for the vent question.0
Thanks KC. Some of the posts on this matter (i read the first 18 pages of 100 on a 2 pipe dropped header search) contradicted one another. I looked in the LAoSH and reread the pertinent chapters and could not find any mention of allowing the header to be lower than the 24" dimension height. TY for your response.KC_Jones said:If you are doing a dropped header the minimum height from the manufacturer doesn't really matter anymore. You need to be above the water line for sure. The more drop you do the more piping options you can have because it give you space. If you want it just above the top of the boiler I don't see that being an issue. I have mine like that and I have seen others do the same. Not sure what the jacket on your boiler is like, but if you need to remove the to panel for any reason keep that in mind with the drop header. On my boiler I made sure to keep the header out in front of the boiler so I could later access the block for cleaning later (mine is through the top). The important part is the height of that first riser and at 3' you should be in excellent shape. I default to someone with 2 pipe experience for the vent question.
- 87.4K THE MAIN WALL
