What air vent is it?
alonm123
Member Posts: 5
Hello,
Can anyone identify the air vent in the attached pictures?
I guess that the radiator is an one-pipe steam sunrad recessed radiator and the air vent is corroded and can't be cleaned. I'm looking to purchase a new one but with no success finding it anywhere and have no name/model/size for it.
Thanks in advance,
Happy holidays folks!
Thanks in advance,
1
Looks like a hot water coin vent, not a steam vent.0
Wow, how long has that thing been used?
Why do you care if its the same one? Just get one that fits your pipe and system type.0 -
I will second that. You need a proper steam radiator vent.SWEI said:Looks like a hot water coin vent, not a steam vent.
I don't care if it's the same one or not, but I couldn't find anything that fits, I tried different steam radiator vents from Home Depot but nothing fits there.
Should I also try to remove the nut or a proper vent should fit right where I removed this old and rusty vent?0 -
That "vent" is for a water radiator not a steam radiator. You need to remove everything so all you have is a threaded hole in the radiator. What is there is a 2 piece coin vent, both pieces need to come out.0
I see exactly the same vents in other rooms of the apartment and even in the lobby of the building (this is an 11 floors building).
Any idea from your experience why water radiator vents were put on steam radiators (if this is really a steam radiator, excuse me for my ignorance)?
Thanks for helping!
Make sure it's steam
If it's hot water your in for a surprise
There is a ball inside that nut that doesn't let water out so you can replace just the front end of the coin vent.
Are you a tenant or owner.
If you rent let the building take care of it.
If they heat up without any air coming out the vent its more likely hot water.0 -
I'm pretty sure it's steam, there is only one pipe that goes into the radiator and during heating cycles if I unscrew slightly this vent then air/steam is coming out.
The reason I want to replace the vent is a very loud annoying hissing/whistling sound.0 -
The original steam vents were replaced by a clueless hack. The whistling you hear is because the coin vents have to be open a bit to let the air out. Unfortunately, they won't actually close once the steam arrives, so in addition to making noise, they are causing the boiler to consume makeup water, which will dramatically shorten its life.0
See attached, I believe they were mainly used on convectors because of space constraints,
http://www.supplyhouse.com/Hoffman-401475-508-1-8-Straight-Steam-Convector-Air-Valve-3521000-p0 -
Many thanks to all of you for the replies!0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
