Hydronics Talk
Mark Eatherton
Member Posts: 5,874
Greetings Refrigerant powered Wallies, We will be doing a session on drain and refrigerant waste heat recovery systems from the team at Swing Green. Join us this Saturday at 12 noon Eastern time as we learn from the experts in drain waste heat recovery and refrigerant waste heat recovery.
Access is available 15 minutes before show time at https://iapmo.webex.com/iapmo/onstage/g.php?MTID=e3fcaee0b516846ce681b7820ef1a38a4
Password is boilertalk
Come out an d learn from the industry's brightest people and see if you may have some potential applications for their wonderful. Products. The show will be archived, but will only be available through the RPA's Members Only web portal.
Thanks and See you this coming Saturday for Hydronics Talk.
1
