Need help identifying and quantifying a possible "Wrought Iron" radiator...
We're trying to do our venting calculations, and I've got a couple of related questions - is the 30" tall radiator in the attached image a "wrought iron" radiator (it matches the descriptions I've read in a couple of places), and if so, where does it fall on the "EDR per section" and "volume of air per sf of EDR" charts?
Thanks!
  • Ba11zooka
    Ba11zooka Member Posts: 7
    edited December 2014
    Just found the EDR/section (here on HeatingHelp, had I just looked :\ ) - it's "1 per tube" (very sneaky, Dead Men, very sneaky), but I'm still looking for the volume...
    Steamhead Member Posts: 18,508
    From the looks of it, I'd measure the tube lengths and diameters, calculate how much air is in the tubes, add 50% or so for the base and see how it works.
    Consulting
  • Just make sure your main venting is generous, and put hoffman 40's on all the rads, and you will have a start at balancing the system.--NBC
    Dave in QCA
