Lochinvar KBN or WHN
Thanks for the info. I've looked into the 0% loan for the full setup in 2014, but unless I tell them I'm going from oil or electric to natural gas my loan only equates to about $1000. I haven't looked into 2015 specifics yet. I did find a source for 0% for three years on an indirect tank thru CHIF. I did have a contractor or two tell me to go ahead and say I have oil "they never check". Asked them to leave right after.RJMCTAFO said:I am located in CT also but not in your area. You may want to look into this also.....
http://www.energizect.com/residents/programs/energizect-heating-loan-program
Paperwork would need to be done by March 31 but at 0% and no fees even if you have the $$ it would let you finance it instead of cracking into the savings account.
The boiler if installed properly will differentiate between the heating call and the domestic water call. It will ramp up to satisfy the water demand and then go back to the programmed curve for heating.
I do mostly oil in my area but typically have found most systems we have replaced with reset are working great with a max temp of 160 on a 0 design day. Some with cast iron rads are running 150.0
- 128 Chimneys & Flues
