field cas4
happydave
Member Posts: 79
For the life of me trying to wrap my head around wiring schematic. Have a fan in can being wired into Burnham 204, looks like I splice into red and white wires coming from/to vent damper, correct?
I copied this response from your other post...
No, splice implies stripping the insulation, and tying all 3 wires together. Note the dotted lines (wire supplied by you)
In reality you would remove the red/white from the vent damper and run the 2 wires to the T1 & T2 on the wiring block. Then get another 2 wire and run it from T2 & T3 on the block to the ignition module TR & TH respectively.There was an error rendering this rich post.
- 62 Biomass
- 114 Geothermal
