Low gauge piping
Steaming101
Member Posts: 30
Hello! Once again what's the best way to install my low gauge. I posted a pic! Tks in advance to everyone's answers, this is by far the best help and advice I've gotten in any forum. https://us.v-cdn.net/5021738/uploads/editor/au/ar8mzqc02osg.jpg
https://us.v-cdn.net/5021738/uploads/editor/an/h2vay3mv66ic.jpg
Here is a picture of how I did mine. Put a tee on top of the pigtail with a nipple out the top for the pressuretrol then mount the gauge on the tee with a nipple and elbow. The picture isn't the greatest. I also added a union on top of the pigtail so everything could be removed for cleaning the pigtail. Just a suggestion, but I would change the pigtail to brass if you can. It will be easier to clean and should actually stay cleaner overall.0
I originally had my gauge similar to KC's but I kept getting water in it so I extended it up higher vertically from the elbow.
No unions on mine, though I may add one when I pipe the 3.0 PSI back in. I originally was going to just eliminate the 3.0 PSI gauge but I like having it to test and set my pressuretrol @ 1.5 PSI.
Christ J where did you get your pigtail? Did you get it online?0
@Steaming101 it came with the boiler. However, I know supplyhouse.com has brass pigtails also.
http://www.supplyhouse.com/Steam-Heating-Specialties-10061000
http://www.supplyhouse.com/Generic-PIGTBRA-1-4-Angle-Brass-Pigtail
Also. Mcmaster Carr has them listed as siphons.
http://www.mcmaster.com/#pressure-gauge-siphons/=ukefskSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Tks! Always helpful0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
