Cast Iron Radiator Help
I just picked up an old slenderized radiator 4 tube 25 inches tall with 28 sections. It was last used in a hot water system and has the hot water input at the top of the radiator and at the other end of the radiator has the cold return flow hooked up to the bottom. Can I keep it setup this way or should I move the input to the bottom as well as I have commonly seen? I am new to cast iron radiators and this great forum and thank everyone for their help!
    Steamhead Member Posts: 18,493
    As long as it's not over-pumped, it should work fine that way. But if the flow rate is too high, the water will just flow thru the first few sections while leaving the rest of the radiator cold.
    Consulting
  • mainewoods22
    mainewoods22 Member Posts: 3
    How can I figure out the flow rate? The pump is a taco 007-F5, going through a short loop (15-20ft) of 3/4" copper. I do have another loop on that zone but it is currently disconnected. So the radiator is the only thing on the zone right now with that pump.
  • field_engineer
    field_engineer Member Posts: 10
    I have converted my home from hot water to forced air. I know you ask, why did I go and do that, trust me it was a fuel cost issue. Anyway, I have cast iron radiators of various sizes, no one seems to want to buy them, I was wondering what I could fonate them?
  • BobC
    BobC Member Posts: 5,566
    People are always looking for radiators. Where are you and what size are they?
    Bob
    3PSI gauge
  • kcopp
    kcopp Member Posts: 4,675
    really where you at?
    Someone told you you couldn't switch fuels unless you also put in forced-air?
    Consulting
    kcopp
