Got a Seek Thermal thermal imaging camera... pictures say a thousand words
agurkas
Member Posts: 238
I might be a tech geek, but I don't treat myself with gadgets. My day is filled with high tech stuff, so I enjoy low tech at home.
But I did spend $200 to get IR camera attachment for my phone and oh my has the urgency to redo cheap pipe insulation and insulate those elbows on team pipes has gone up.
Yes, you will notice none of the risers are insulated. But even those pipes that are, the 1/2" stuff is just not cutting it.
Also, I was ready to tear into the wall to figure out where the heck the hammering pipe is exactly. As you can see from the pic below, not hard to find now0
Pretty compelling evidence. Someone posted similar pics a couple of years ago showing the effect of adding a reflective backing behind radiators as shown by exterior heat loss. Needless to say, I immediately added it behind ALL my rads.Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF0 -
This is very cool. I've been looking for a good way to check for broken steam traps. My IR thermometer doesn't do so well on the reflective surfaces of the traps.0
What material did you use? I was thinking doing like a stainless steel or coppervaporvac said:Pretty compelling evidence. Someone posted similar pics a couple of years ago showing the effect of adding a reflective backing behind radiators as shown by exterior heat loss. Needless to say, I immediately added it behind ALL my rads.
Aluminum sheet or even the reflective bubble wrap insulation should work well.agurkas said:
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
