Logamatic display
TLM
Member Posts: 38
in Oil Heating
I have a logamatic 2107 on a Buderus G115 oil fired boiler. Yesterday all was well. This morning- no hot water call. There are no lights or display. Power is good. Fuses are good. I put it in manual and dialed the aqua stat back to 140 from "AUT" any ideas? Do I have a faulty display or is it worse?
Have you checked to see if there are fuses in the logomatic controller itself and that the controller itself is receiving power? If the controller is receiving power and there are no faulty fuses the units power supply may have failed. If you know anything about electronics look around and see if there are any suspect solder joints.
3PSI gauge0 -
Fuses are good. If they weren't the burner wouldn't fire.
In that case it's either a failed component in the controller or a bad connection or solder joint.
3PSI gauge0 -
Thanks. I'm going to call Buderus in the am to see if they've had any issues etc....
- 125 Chimneys & Flues
- 19 Recall Announcements
