Do Circulators Lose Their Circulating Ability With Age?
What's the useful in service life? I have 2 Taco 007-F4 for the heating loops, both are 20 years old.
  • icesailor
    icesailor Member Posts: 7,260
    Water well pumps loose efficiency with age. Heating circulator pumps will too I'm sure. The only time I ever saw it happen is when either the impellor broke off or something chewed the vanes off.
    hot_rod Member Posts: 27,831
    depends on the life they lead.
    Properly sized and installed? Good fluid or water quality, no grit, rust, etc?
    No oxygen ingress from non barrier radiant tube?
    Adequate air removal device?
    That is a hearty pump, could last another 20.
    Without measuring the performance, or removing and doing a visual inspection, hard to say.
  • Docfletcher
    Docfletcher Member Posts: 490
    Both Taco's as well as the 1 Grundfo's are whisper quiet for what that's worth. All 3 heating zone baseboards pipes are too hot to touch for more than a second, both at the entrance and exit's of the finned baseboard. That would suggest flow I think.
  • Bob Bona_4
    Bob Bona_4 Member Posts: 2,080
    The only wet rotor pumps like the 00s etc that I have seen "wear out" are either cast iron ones used for steam condensate heating (wrong application) or something like the 006 bronze used for aquabooster duty- the impellers can turn to powder. Otherwise they last decades without any apparent degradation-usually to the end of life of the boiler!
    Docfletcher
  • Docfletcher
    edited October 2014
    Thanks all. It's all good info. So I guess I can save my dough at least for now.
