put ball valve(s) on each water heating baseboard branch?
heatingFun
Member Posts: 84
Just wondering is it a good practice to put ball valve on each baseboard branch in a water heating system? one side or both side (in and out)?
@heatingFun
Never a bad idea to have a lot of isolation valves in a system. If you do install them, I would also put in a drain fitting on each branch so that you can drain each one on its own.1 -
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
