Which Nozzle to use.
Harvey Ramer
Member Posts: 2,290
in Oil Heating
I have been tasked with repairing this gluttonous hulking dinosaur.
http://www.discountstoves.net/Glenwood-3050-Automatic-Multi-Fuel-Furnace-p/3050gw.htm
The one I am working on is older and does not have the hx fins on the oil combustion chamber. It is rather just a 2' diameter by 2' long round tube that exits into the back of the fire box. I am lining the tube with a wet blanket and patching the cracks with furnace cement. Also I am replacing the oil burner.
Question is, what kind of nozzle might be best suited for this unconventional application? I was thinking of maybe starting with a type B @ 40° to 45° angle.
Harvey
Harvey
What burner are we talking?0
AFG Beckett 9" tube.0
70 degree is as narrow as I would go on the AFG. This isn't a L or N head? Just the typ F head?0
Burner head is L1. Tube assembly is AFG90MB.0
Go with the 60 and jack er up to 150 or so and see how it looks. The 45 might impinge?0
Thanks Bob. I'll give it a try.
Harvey0 -
Let us know..I had a Tarm rehab once..similar.0
@Bob Bona This furnace has no barometric damper. What are your thoughts on that? I know oil should have one but what about the wood?
Harvey0 -
Getting above my pay grade Harvey
My first thought is I can see the oil draft be damned in the interest of proper wood draft? 0 -
And if you install a barometric damper like a Field RC on the flue. you should see how red the pipe can get when you get a chimney fire. You hear that jet engine roar in the chimney, you go outside and look up at the chimney, and think that a V-2 Rocket went down the chimney.captainco said:Wood furnaces and boilers usually require a -.05"W.C. draft at the outlet. The draft for oil will be what it will be. Excessive draft makes the wood burn to fast and low draft smokes up the house.
- 125 Chimneys & Flues
- 19 Recall Announcements
