Rococo American Radiator Air Vent Location?
MRW
Member Posts: 5
I recently picked up two 38" tall 3-column Rococo radiators made by American Radiator Co. The guy I purchased them from had used them in a hot water system, and I'm adapting it for my 1-pipe steam system. So as such, there is currently no tapping for an air vent. There is a boss on the center column, very near the bottom... would this be the correct location to drill and tap for the air vent? It just seems so... low. I attached a pic of someone else's Rococo, with the boss circled in red for reference. There are no other such areas (except for the air bleed tapping at the top, which I was going to plug for my purposes). Just wanted to check before I pull out the drill. Thanks in advance.
That boss is the correct steam vent location on a water-type radiator. On a steam-type, the boss is usually a bit higher.All Steamed Up, Inc.
Consulting1 -
Thanks for the insight guys, I didn't realize they made different designs/castings depending on the intended use. I'll go ahead and drill the boss. Thanks again!0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
