Pressuretrol cut in was set higher than the cut-out
Alix
Alix Member Posts: 30
We have one pipe steam heat. I'm getting ready for heating season and noticed the pressuretrol cut-in had somehow been set at 2 psi while the cut-out (round plastic wheel) appears to be at 1 psi (the '1' on the dial is at 6 o'clock). Looking at my Holohan guide I see the cut-in should have been set at .5 psi. I'm surprised as everything appeared to be working fine last heating season. What happens when the pressuretrol cut-in is set higher than the cut-out?
  • Alix
    Aha! Boy do I feel dumb, first for having let the cut-in be set at 2 psi, and more recently for misinterpreting the dial! I think I got it now, many thanks! I reset the cut-in to .5 and left the differential at 1 psi.
