solo 250
smklin
Member Posts: 69
My triangle tube solo 250 goes into no flame ignition regular replaced the ignition cable did a combustion test checked gas pressure have about a 1.5 inch drop what could be my problem
Did you
replace the igniter? I had the same problem with a new unit and a new igniter took care of it. Is it still under warranty?
Alan8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 62 Biomass
- 114 Geothermal
