How to maintain the gas fired steam boiler
jacker
Member Posts: 2
in Gas Heating
Gas fired steam boiler,as one kind of environmental protection industrial boiler,has become the hottest-selling product because of its remarkable advantages.In order to ensure the normal and efficient operation of gas steam boiler, we must pay enough attention to maintenance of the boiler.Zhengzhou Boiler Co., Ltd,as an experienced industrial boiler manufacturer,gives the following advice to maintain the gas steam boiler for your reference.
The processing of feedwater must be qualified,which is important issue to extend the service life and ensure the safety operation of gas steam boiler.
The temperature of feedwater should be close to the furnace’s, preferably above 20 ℃.
The low water cut-off devices must be checked,cleaned and maintained regularly.The water level controller must be cleaned at least once a month,while, the water level indicator should be washed at least once a day.The water level indicator should be washed at the highest water level,the water level should not be below the lowest safe waterline after rinsing,it can be cleaned repeatedly.
The regular operation of pollution discharge is needed,at least once a day(class),after the pollution discharge,we should check that whether the blow-down valve has the leakage,it must be excluded if it has the phenomenon.
When the furnace was stopped without maintaining the pressure of steam,the steam space of the boiler will produce negative pressure and has air entrapment,so,the total steam valve should be opened first when we begin to ignite again.
The fouling of smoke tube leads to the rise of the exhaust temperature, so that the efficiency of gas steam boiler will reduce.Therefore,the cover of front and rear door should be opened regularly to brush or blow the fouling of smoke tube.
The <a href="http://www.zgindustrialboiler.com/product/oilgasboiler/list_1_1.html">gas steam boilers</a> of Zhengzhou Boiler Co., Ltd,use the advanced corrugated furnace and the thread smoke tube,which increases the heat transfer effect and the boiler thermal efficiency. The recognition form customers at home and aboard shows that the products here are reliable,the gas fired steam boilers also have many advantages beyond your imagination,for more details,please feel free to contact us!
Hacksters:
A comment from Jacker the Chinese Hacker.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
