Attention to the use of steam boilers in the industry
jacker
Member Posts: 2
In the industry, if people need to use high-temperature steam , then the steam boiler will be used; water can be heated to a quite high temperature, and generates high-temperature steam . Steam boilers and other hot water boiler are not the same , if people want to use the steam boiler, the boiler must be certified , or else once operated wrongly , then the consequences are very terrible.
Steam boilers in the factory need relevant instructions and certificates, and only owning all these things , that will be truly qualified steam boilers. If you want to install steam boiler, repair or renovation, so the transformation of the unit certificates must be relevant to prove himself to get the regulatory authorities for their installation, maintenance or improvement of accreditation and certification of the boiler. If the boiler construction units want to carry out these operations , they also need to provide written announcement of the relevant departments , besides they also need to record the project,then the construction can be carried out.
After the steam boiler installation, repair or renovation are completed, the relevant departments have to check, and only when it is qualified, then it will be accepted. At last, it need to be registered on before the steam boiler is actually used . Steam boiler can only be operated by those staffs who are certified professional people, and the operators should behave strictly in accordance with the operation rules of the boiler. For the safety problems, steam boilers require regular inspection, which is conducted every year. If there is no regular inspection of boilers and safety accessories that can not be used , which is only to protect people 's safety, and in case of any dangerous accidence happens
Steam boilers are usually used in the industries , it is important and necessary to operate carefully in order to ensure safety. ZG reminds you of paying attention to the use of industrial steam boiler.
<a href="http://www.zgvessel.com/news/industrialnews/Attention-to-the-use-of-steam-boilers-in.html">http://www.zgvessel.com/news/industrialnews/Attention-to-the-use-of-steam-boilers-in.html</a>
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
