Ownert
taco
Member Posts: 3
I have a Gibson heat pump 3 ton 2 stage cooling back up 15 k elect I don't know if the blue wire from indoor unit goes on the themostate
Blue Wire
If the blue wire is the common leg of the 24 VAC side, you usually don't need common to the thermostat unless you have lights or a digital screen.0 -
owner
sorry i forgot to turn power on to outdoor unit thanks for your help0 -
DOH0
- 125 Chimneys & Flues
