phoenix light duty .50 gal water heater.76,000 BTU
Gerry1
Member Posts: 3
Hi /there. This is my first post. I purchased the above water heater .with the intent of adding some hydronic heating. in the near future. However i need to set it up to replace my existing electric heater for DHW, I have run gas to it . Has anyone set one of these up.wondered if you had any tips. I have a seperate boiler room attached to house,.NOt sure in i need to install an expansion tank on DHW side, I know there are no backcheck valves to the water meter. Thanks Gerry
