Dunkirk Series 689 Manual
Greg S
Hello,
I purchased a building which has been unused for a number of years. There is a Dunkirk (retagged Crown Jamaica) steamer around 10 years old. The Jamaica site is impressive, but dos not cover this model. I am looking for a manual.
Dunkirk Series 689
Model JS62E? (? most likely N for natural gas)
Serial # Field Conv
Natural gas 187,000 BTU input
Color - blue
Thank you,
Greg Shattenberg
Dunkirk Series 689
Serial # Field Conv
Color - blue
Thank you,
Greg Shattenberg
Manual, cont --
Hello,
After more inspecting, this appears the closest (JBF62EID):
http://www.crownboiler.com/manuals/content/All_Models/Jamaica%20(JBF-SPD,%20JBF-EID).pdf
The exhaust is more to the center than front, and there are no cutouts on the front for anything.
-- Greg0 -
Where are you located?
there should be a pro nearby who can help you with that system- not just the boiler, but the system itself.All Steamed Up, Inc.
Consulting0 -
Continued
Hello,
With extra glasses and lighting, it is
Model JS62EI
Located in Auburn, Maine
I will use a pro with the gas connections.
Not the one stickered on the boiler (Bullhead T, no skim T, no header, single riser, along with minimal main venting).
Thank you,
Greg0
