Tom Schwarz' Tools
As many of your you are aware,Tom Schwarz( TGO) passed away in February 2014 very suddenly. His widow would like to find a good home for his tools,where they can continue to do the work he did with them. Tom was a meticulous craftsman and his tools are used but in incredibly good condition. If you are interested in anything,send me a PM. Thanks!
Powersaw guide support
REMS auto threader
Tornado 2000
Curvo bender,electric
pipe stand
Amigo 530021,540021
kindorf clamps asst
aargo post base 2 sizes
Mupro lag screws
Hilti TE70
Hilti bits
Hilti DX36
Hilti anchors
used guage manifolds
48" alum pipe wrench
48" steel pipe wrench
large rigid pipe cutter 48"
36" alum pipe wrench
36" steel pipe wrench
pipe cutter
rems cutting oil
portable ventilator 39012W
assorted pipe wrenches
knockout punch set
TiF5600 leak detector
electric snake/drain
conductor shrouded cable #18 wire
acetyline tanks
PVC plumbing fittings
Imperial pipe bending kit 364FHA
insulated ref lines
  • Revised
    Item Number
    Pex tool kit 1
    assorted pex fittings 100
    pex tool 1
    Wirsbo multipress D6275063 1
    CA-6100 Combustion Analyzer 1
    Assorted hilti bits 12
    Hilti TE5 drill 1
    Hilti TE74 1
    Solar pathfinder 1
    9010A Electronic refrigerant scale 1
    Extech RF-40 Refractometer 1
    Pex line 1/2 inch 220
    Pex line 1/2 inch 39
    Pex line 5/8" 330
    Pex line 1 " 471
    Pex 5/ 8" 95
    Pex line 1 " 45
    Pex line 1 " 46
    Pex Uncoiler 1
    Tile master-Felker tile saw 1
    50 lb recovery cylinder new 1
    50 lb recovery cyl old 1
    25 lb R410A 2
    DH 16-I drainhose 175
    MAT240 absorbant pads 18" 1
    Expansion tank PT-12 1
    Expansion tank HFT60 1
    tin wipes hand ? Box 1
    1/2" seal tite 40
    Wohler digital Meter 2
    come along 1
    Viessman D35107 oilline 1
    Appion G5 twin recovery unit used 1
    slim duct trim 1
    Mupro pipe clamps assorted 894
    REMS 4" driven hand saw 1
    Powersaw guide support 1
    REMS auto threader 1
    Tornado 2000 1
    Curvo bender,electric 1
    pipe stand 2
    Amigo 530021,540021 2
    kindorf clamps asst 50
    aargo post base 2 sizes 2
    Mupro lag screws 1000
    Hilti TE70 1
    Hilti bits
    Hilti DX36 1
    Hilti anchors 1000
    used guage manifolds 4
    48" alum pipe wrench 2
    48" steel pipe wrench 2
    large rigid pipe cutter 48" 1
    36" alum pipe wrench 2
    36" steel pipe wrench 1
    pipe cutter 1
    rems cutting oil 4
    portable ventilator 39012W 1
    assorted pipe wrenches 14
    knockout punch set 1
    TiF5600 leak detector 1
    electric snake/drain 1
    acetyline tanks 2
    PVC plumbing fittings 150
    Imperial pipe bending kit 364FHA 1
    insulated ref lines 100
  • Revised
    The list was missing some items and has been revised. You can contact Tom's widow at JMCorcoran@optonline.net for more info.Thanks!
  • meplumber
    meplumber Posts: 673
    Location
    Mr. O'Brien,
    What part of the country are these tools in?  Northeast?  They don't make stuff as good as they used to.  Some of this stuff is in a quality that is hard to find now.
    I might be interested in some of it.
  • Isle of Long
    East Northport to be exact
  • MikeyB
    MikeyB Posts: 696
    Rob, do you know if the Rems Curvo machine still available? I tried emailing Toms wife but the email got kicked back to me.. Thanks
