Navien CH240 drawing intake air from basement?
Ross_24
Ross_24 Member Posts: 82
Just visited a new client of ours to take a look at their new heating system install. They have a Navien CH240 that is drawing intake air from the basement, instead of the usual outside air intake.
The manufacturer does include an option for non-direct venting, although it seems insane unless absolutely necessary (of course, in this case it's not necessary at all). In this case I believe the old dusty basement would quickly void the warranty.
Anyone else seeing this?
  • Rich_49
    Rich_49 Member Posts: 2,785
    Besides
    the possibility that if the house is tight where will the unit gets it's makeup air from then after inside air is exhausted ?  Not a good install in my opinion .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
