Summer shutdown notes
Maine Vent
Member Posts: 130
Well after a brutal, long, cold, winter & spring here in Maine I finally got to summer shutdown.
Still need to get my service Tech over for burner check.
Burned a lot of NG this year, but we were warm.
My VXT measured between 1 & 2 gallons of make up water.
Flushed boiler, and 2 condensate sections for about 3 hours, water was finally nice and clear.
I would like to of tried the WAND TECHNIQUE but I was gun shy on taking out the bottom plug. I tried, but will wait for the Tech. who knows and has the right wrench.
Thanks again for years of valuable insight, and Dan's Books.
Pass on your knowledge, to other steamers, no matter what your knowlwdge.
Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal
404 sq ft EDR
Water
From what I've seen I use between 1 and 1.5 gallons of water per heating season. I used to use less, until I switched to Gorton vents on all radiators and added a lot more venting. I suspect all of my water loss is via venting as we all know the air coming out of the system is very humid.
If you think about how many times a system breaths per day, for example on a typical cold day my system breaths out at least 48 times a day. So my opinion is, the faster you vent, and the more cycles you run the more water you will use.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 119 Geothermal
- 394 Solar
