5 inch pvc
Snowmelt
Member Posts: 1,454
On these takagi TM-50 I went to service has 5 inch pvc for fresh air intake.
There in a comercial application ( 6 ) units, the fresh air intake is to close to the exhaust, I know 5 inch pvc isn't a stock item.
Do you think it's just easier to get 6-5 inch bushings.
The contractor has 5 inch elbows then has a little stub roughly 6-8 inches comming from the elbow itself.
Again the question is it is easier to get 6-5 bushings & just go with the 6 inch pipe & elbows as needed.
