Replacement Radiator vent doesn't seat well
agiledan
I'm slowly replacing some of my tired old Barnes and Jones radiator vents with vent-rites (which I've been very pleased with). I just unscrewed an old vent, and it took two full turns to get it out. The new vent goes in one and a quarter turns and is then finger tight. I can force it, but I have not much experience with this. Am I likely to crack the radiator? Or break off the the valve stem? I wrapped the threads in some layers of teflon tape, but it seems to make no difference. Should I use pipe dope?
Dear Abby ... what should I do?
Never mind!
I just swapped the too-tight fitting valve with the valve from a different radiator, and now they both fit just fine. Doh!0 -
Use a die
A 1/8" NPT die can be used to chase the valves threads. You can exert a reasonable amount of force on the vent, often the last turn is hard., I just use a couple of wraps of teflon tape. I would never try using a wrench because you could over torque it and break something
3PSI gauge0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
