Converting
Snowmelt
Snowmelt Member Posts: 1,457
I'm converting from oil to gas ( just had gas put into the home) steam boiler.
I have two rooms that have radiant floor installed from bottom with aluminum plates.
2 questions. Can I have a indirect water heater comming off the steam boilers return for domestic water?
Can I have a secound indirect (thinking peerless low boy) to do the radiant floor? Or am I thinking to hard.
Ultimily I want to size the home for the heat load, I might be able to seriously cut 50,000 btu off the boiler.
Should I get a water coil in the boiler and add a indirect for domestic?
Should I get a 2nd indirect for radiant floor.
