FST-200 Boiler Breeching Rumble after conversion to gas
jblum
jblum Member Posts: 13
There is a pronounced rumble in the horizontal breeching of the 200 horsepower FST-200 boiler with IC burner after conversion from #2 oil to natural gas.    The boiler and burner are is 20 years old and never rumbled before conversion to gas.    Part of the conversion involved installing a stainless steel liner in the vertical masonry chimney.      In the boiler room, the breeching was not changed, but it was re-insulated with lighter insulation after removing the old heavy lagging.
I am looking for referral to an specialist who can help.
Jim Blum
  • Weezbo
    Weezbo Member Posts: 6,231
    edited April 2014
    it is early , my first cup of coffee,
    is it possible the combustion air requirements have not been met?
    for a quick idea where to look?
    if the room has an opening like a window or door to the outside
    and you open it, during start up and testing ,
    your results are different than with the window or door closed ,
    Then , there is insufficient combustion air intake , for an example.
    Safe
  • Weezbo
    edited April 2014
    as i have not heard back from you
    would you consider calling the mechanical contractor who installed the burner ?
    Let them Know that this happened?
    Thank You.
    Steamhead Member Posts: 18,547
    If memory serves
    the Federal FST boilers run with a slight positive pressure in the firing zone. Check to see that the breech damper is properly set.
    What were your combustion test readings?
    Consulting
