outdoor reset
add
Member Posts: 94
in Oil Heating
I would like to install an outdoor reset on my 3 section oil boiler,4 zones(including indirect) pipe with circulator , wired with the argo box. Any advice? Thanks.
Which boiler is it
and how is it vented?
There are a lot of things to take into consideration, with ci oil boilers, I like to pipe them primary secondary when using an odr, I also like to have outdoor combustion air piped in and use an efficient circulator like the taco bumble bee set up for delta t....
I use the hydrastat 3250+ control with the os100 kit as a start...
There are other options like temp target controls that can work similar to an odr available also....0
- 125 Chimneys & Flues
- 19 Recall Announcements
