New boiler supply/return question
slowheat
Member Posts: 1
in Gas Heating
Hello,
I recently had a high efficiency Alpine gas boiler installed rated
at 95%. We have hot water baseboard in the house. When it was first installed, I observed that when the water
temperature exited the boiler at 180 degrees, it would return at 160
degrees. I was informed that the 20 degree difference was the correct
ratio. We have a Taco 0015 mulispeed set at #2 (3 speeds) going to the boiler, and
a Taco 0011 going to the rest of the house. We have approximately 69
feet of baseboard covering the living area of the home (1 floor). I
noticed that the the house heats slower now than it did before when we
had a oil boiler, but we understood that is part of owning a high
efficiency boiler.
I noticed I have a lot of exposed copper piping in the basement. I
purchased Armacell 2.3r polyethylene insulation and covered
approximately 40 feet of the piping in the basement that leads to the
first floor baseboard. During the winter the basement gets into the low 40s. Once I covered the exposed pipes, I noticed that
the return temperature to the boiler was over 170 degrees, sometimes
up to 175.
We do not need heat in the basement, that is why I covered up the
pipes. Is the lower differential (10-5 degrees as opposed to 20) a sign
of a problem? Or is there a way we can get the differential closer to
the 20 degrees and have our living area heat up faster?
efficiency boiler.
up to 175.
DId your installer
wire up the outdoor temperature sensor and configure ODR on the boiler?0 -
New boiler spply/return question
yes they did. the boiler doesn't always run at 180 degrees, but when it does, the return is over 170. it's the same when it is running at lower temperatures0 -
Taco 0011
This is a pretty unusual circulator for baseboard hot water.
What is the cycle time on the boiler?0
- 125 Chimneys & Flues
- 19 Recall Announcements
