Hydronic stuff
devo
Member Posts: 20
For sale: Numerous hydronic components: Tekmar/Wirsbo/ Uponor promix 101 with Belimo 1" 3-way valve (used), Wirsbo 1" Differential bypass valves x 2(used), Buderus Logamatic 2107 outdoor reset (used), Tekmar 650 snow melt controller( New), Heliodyne gobi 4'x8" solar panels x 4 ( new), 18 gallons heliodyne solar antifreeze(new), GeoThermal flow center(new), DanFoss 3/4" TRV(New), Babington airtronic burners- fully functional (used), HTP 120 gallon custom indirect water heater/solar /316 stainless steel/ cupro-nickel(used), Sparco 1" air eliminator( Like new), waste oil pump module( Suntec, watts, lovejoy, Velcon) (used).Solar expansion tank(new). All items are full functional and are guaranteed to work as designed as new.Also, Slant fin slimline 30 end caps/ Rights and lefts x 20 each (new) Please contact for more specifics. Thanks!
NEED ONE OR 2 SIMPLE INDOOR /OUTDOOR BOILER CONTROL TO MODULATE SIMLE BOILER.. TECKMAR, INTELLYDYNE ALMOST ANYTHING CONSIDERED0
- 125 Chimneys & Flues
