Insulation changes everything
JUGHNE
Member Posts: 11,513
In the process of adding 1" FG to steam piping. (Never had insulation) Two 3" mains are 113' & 107'. Mains are 85% done. One 2" return is 80% done. System used to run 3 to 7 ounces pressure and only cycle with T-stat. Now pushing 1 lb pressure. Finding several leaks (rad bonnets/unions etc. that never were there before). The pressure control is set down all the way; screw ready to fall out. I know it is worthless for this system but never needed one until now. So is it obviously time for a vapor stat control? One note when pressure is up to 1 lb and power switched off a vacuum is reached in 6 minutes (twisting a 32 oz gauge needle around past 0 up to the "32" number at least. Compound gauge might be on 1" HG). 28 minutes later we are back up to 0 psi. Power on and 28 minutes later we are at 3 ounces. Is there any to use this vacuum to still heat or have I not read Dan's books enough? Each main has a Gorton 2 & a Hoffman 75 (more to be added later) rads have Hoffman 40 & some 1A. Any thoughts appreciated.
- 114 Geothermal
