WM Eco Boilers
knotgrumpy
Member Posts: 209
Has anyone here had any experience with the WM Eco Boiler?
Here is a link to a brochure on it. Sort of a stripped down WM97. Firetube heat exchanger and a fairly attractive price, which I won't mention here.
<a href="http://www.weil-mclain.com/en/assets/pdf/ECO_Brochure_0513.pdf">http://www.weil-mclain.com/en/assets/pdf/ECO_Brochure_0513.pdf</a>
Thanks,
Mark
Thanks,
Mark
Eco
We have put 2 or 3 in.
Perfect for replacing a failing modcon.
Has ODR, basic control, good price point.
The value is there.
-Andrew0 -
Control panel
Can that be extended to a location else where in the home? If not I like that idea........in the right hands, or with limited home owner access.0 -
2' Away
Gordy -
According to what I read, the control can be mounted on the boiler or up to 2' away.
Handles ODR and domestic priority.0
