Burnham IN5 with Cycleguard LWCO
Liftforward
Member Posts: 13
So what I thought was short cycling actually appears to be the lwco doing it intermittent test. But on the bright side. all my pipes in the cellar are insulated, including the near boiler pipes, I have 3 gorton #1 on both main lines, cleaned the pig tail, added a 0-3 psi gage with the pressuretrol, a bunch of new adjustable rad vents and the rest are clean.
So after reading the install for the cycleguard, it appears the safecycle is 'optional' and the wiring looks like the addition to the module. Model CG400.
Has anyone just removed the optional wiring to remove the intermittent water test? Thinking of either doing it myself or getting the installer to do it. Don't like the idea of getting a diff lwco.
Any thoughts. Thanks.
Nothing Optional about it
Finished talking to technical at hydrolevel and all the optional in the literature refers to is the timer. The unit will still cycle off every 20 min. but without the wiring, the timer won't reset after the last cycle.
So what does the commuity think should be the replace for this poc. Thanks.0
