Pipe Hammering
Main issue is loud pipe hammering (consistently off and on). New Weil-McLain EP/PEG Series 5 gas boiler installed a year ago with this problem ever since. Installer has not been able to solve and advises main cause is rust. Pressure gauge to set to 1.5 and to less than 1-psi subtractive cut-in pressure now.  This was done due to a kind expert's email advice and whose advice included my presenting this for discussion on The Wall.
I have attached picts 81, 82, 84, 85, 86 and 89
I am definitely a novice/layperson and I extend advance thanks for any help I can get..
  • ChrisJ
    ChrisJ Member Posts: 17,373
    edited February 2014
    Piping
    Comment removed.
    I just noticed that looks like a counter-flow system and I have no experience with that although to me, I don't see that header working.
  • JStar
    JStar Member Posts: 2,752
    Hammer
    Boiler is installed wrong. Find a copy of the instruction manual, that the installer threw out, and throw it at him.
  • EzzyT
    EzzyT Member Posts: 1,379
    Boiler piped wrong
    As Chris and joe said there is no equalizer on the header that bull head tee has go not enough height from the water line to the bottom of the header. Plus I don't see any steam main vents on that system
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
