I think I have a stream radiator. Definitely have a high pitched whistle problem!
Whistle_Help
Member Posts: 8
Hey,
I just moved into an old apartment complex and discovered a very annoying high pitched whistle when the radiator is in operation. It is very old, had two pipes, I think it is steam, is completely painted over, and has no adjustable posts as far as I can tell. Is there anyway to stop this whistle? I have included some pictures.
Thank you!
Thank you!
Radiator
Well, at least there's a "trap" on it.
Is there also a lot of gurgling sounds?0 -
I could not tell from the photo
whether it was steam or hot water. The top of that "trap" looks like it could be a shorn-off angle-pattern valve.0 -
Rad
Looks like hot water from the pipe sizes. Although, it also looks modified, so who knows how it was originally installed?0 -
I have not noticed any gurgling. Just the whistle. The system was off earlier today and I had relief from it.
Is there anyway I can manually turn it off with the trap?0 -
Actually,
There is a bit of a dripping type sound.0 -
So
I think I might try to undue that top nut. Am I right in thinking that is the Lockshield cap? And underneath I will be able to turn it off?0 -
Rad
I would be cautious. First, find out exactly what kind of system you have. If it's hot water, you'll make a huge mess trying to open any of the valves or piping.0 -
Ok.
I might call someone to look at it then. The landlord just purchased the property and didn't seem like he wanted to do anything when I mentioned the noise.
Would I call an HVAC specialist?0 -
Rad
Where are you located? We may know a boiler expert who can help.0 -
I'm
I'm in Salt Lake City, UT.0 -
Take some pictures of the boiler
Who pays for the heat in the building?--NBC0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
