Skim via Pressure Relief Valve Port?
dubbsi
Member Posts: 18
Is it ok to skim via the pressure relief valve port if I don't have a skim port? I have 1-pipe steam system that's spitting water out some of the vents, and I want to do everything I can before resorting to redoing the flawed near-boiler piping.
Is there a reason for having a skim port installed just for the purpose of skimming?
The pressure is not very high - I'm still getting spitting at 1.5psi.
Thanks in advance!
Thanks in advance!
skimming
That is where I skim mine from. I have it set up with a tee and a valve so that I don't have to remove the pressure relief valve when I do it.0
- 117.6K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 403 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 682 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 12 Recall Announcements
