kick space heater with steam
radmix
Member Posts: 194
I would like to connect a kick space heater to a steam boiler using the tappings on the boiler below the water line. I will be using heat pex a circulator with a relay. Does the circulator need to have a brass body because essentially its an open loop system.
pump
Yes it should be a stainless steel or bronze. I would also suggest not using a wet rotor pump but an air cooled model.
If you do use a wet rotor put a 100 micron strainer with a drain before the pump.0
- 120 Geothermal
- 394 Solar
