Cutting Baseboard Enclosures
Bob Gagnon plumbing and heating
Member Posts: 1,373
What is the best way to cut Hi Output Baseboards enclosures. I'v used a carbide saw in the past, but tons of sparks, would electric snips work OK? I use slant fin and it's really thick'
Thanks, Bob Gagnon
Thanks, Bob Gagnon
Saw
I have tried several ways (including elec. snips) and I still think the easiest is a chop saw with a carbide blade. as long as you grind off the sharp edges. The one time I tried the snips, it ended up bending and warping the first piece beyond repair, and the second piece broke my snips. Maybe they were dull? don't know, but I used a saw for the rest of the job.0 -
Cutting baseboard enclosures
I use a good pair of aviation snips, lefts and rights or reds and greens. Keep your cuts so the end caps will cover them. Klenk snips are what I use. Measure twice, cut once.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 966 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
