strange vent
![joewolf](https://secure.gravatar.com/avatar/3829f2571d732792e69f840229d70a06/?default=https%3A%2F%2Fvanillicon.com%2F8eab67a4527afed78b20301f79e02a15_200.png&rating=g&size=200)
joewolf
Member Posts: 19
hey guis i calculated the volume of the main and is about 1.142 ,on the previous post i have said that on that main i have fuor radiators 2 are getting hot and two are not i'm going to post pic of the vent ,that is place on the return when it drops ,i did take the vent off i blow through it and air goes through i blow on it fast and the boll came up i would assume the vent is good .i take the vent off for one cycle and no change the 2 radiator are still cold ,i did change the vent on the radiators with the biggest vent that there is and no change ,i notice when there is a long cycle they do get hot ,so i think my only option is to put a thermostat on the cold room. any other suggestion? thanks in advance .JOE
Maybe
the rest of the house is venting too quickly?All Steamed Up, Inc.
Consulting0
- 85.8K THE MAIN WALL
- 51 Biomass
- 419 Carbon Monoxide Awareness
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 860 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 40 Industry Classes
- 16 Recall Announcements
