Size of main vents required
cdm
Member Posts: 77
I have a one pipe system with 1.22 cu.ft. of volume in the 1st main and 1.89 cu.ft. of volume in the second main. I want to REALLY quickly vent both mains in a few minutes - how much venting do I need @ 1oz.? Gortons or Hoffmans ?
thanks -cdm-
thanks -cdm-
Gortons
The Hoffman 75 vents at 0.5cfm , the Gorton #1 at 0.33cfm, and the Gorton #2 at 1.1cfm -all at 1 oz. What kind of vents are on there now?
It sounds like you want to start with a G#2 on the small main and a G#2 and 2ea G#1's on the large main. If you currently are using Hoffman 75's two of them pretty much equals a Gorton #2.
3PSI gauge0 -
Bob - On the smaller main I have a Gorton # 2, on the larger main I have 2-Hoffman # 75s and a Gorton # 1. So i guess the sizing I have is O.K.
Thanks for your input - I really appreciate your expertise. -cdm-0
- 114 Geothermal
