Wiley Safety Vent Vapor Regulator
CaptainSolo43
Member Posts: 1
I have an old low pressure steam system. One part of the system is ancient! it is the Wiley Safety Vent Vapor Regulator. If you type it in Google you will find my exact system. Just curious what I can do to replace it with a more updated venting system for my newly replaced steam boiler.
you could
always put a couple gorton #2 vents on the air vent pipe leading to the vent. Keep boiler pressure low on those systems.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 114 Geothermal
