bryant 352 with LP conversion
ollies69
Member Posts: 4
I installed this furnace 8 years ago for a buddy, he called the other day and said it would not light. I found the roll out switch tripped and the intake pipe burnt. I replaced the primary and secondary heat exchangers as they where sooted up and plugged.
Now the furnace will go thru the normal start sequence I can only get 9 inches WC coming out of the gas valve and it will not light. I would think it should at least light with this pressure, the manual calls for 11 .
Gas valve orifice
Or maybe the regulator at the tank. Call the propane supplier on that.0 -
lp tank
I was thinking that also, but there is another furnace that runs from the same tank. I also checked the manifold orfices they are all clear.0 -
Can you
adjust the wc up at the valve? If not, then it must be the valve itself by process of elimination. Vents are all clear, right?.0 -
vents
I have cut both pipes open and checked them. I tried to adjust the wc. up more and the adjuster bottoms out at 9.
My next step was to replace the valve, I just never seen a valve fail like this before0 -
Solution
Ended up being a faulty gas valve0 -
Be sure
to clean off the flame sensor too, it probably has some carbon on it that will start to interfere with the signal.0
