Homeowner needs advice
Brockworth
Member Posts: 7
Hi, I know it is Xmas eve but we need some advice/info.
We have noticed that our Teledyne Laars boiler Model # D-JVS-125-C is making noises on this very cold day here in Winnipeg. When the thermostat calls for heat, sometimes there is a buzzing or rapid clicking sound coming from the boiler upon start-up. Sometimes it stops by itself. Sometimes if we turn the thermostat down and back up again the noise stops and then the boiler sounds normal. We have returned to the house, from being away and found that buzzing/clicking noise already going (who knows how long it has been going?) and with it we hear loud knocking, bubbling sounds in the pipes. It only happens intermittently. I cannot re-create it. So... I do not want to call somebody here, today, if it cannot be re-created. Please can you tell us what you think it might be?
Tks,
Tks,
Faulty aquastat not shutting off?
Best to turn that boiler off for the moment, and look at what temperature/pressure is showing on the gauge. It may be boiling due to the aquastat not cutting off the burner when the set temperature has been reached.--NBC0 -
Photo of the Temp & pressure gauge
Hi …
Thanks for the reply. Sorry for the delay… I had to find my phone to take a photo of the gauge.
Please see attached. It seems normal…?0 -
Is it possible that
Is it possible that the pump is not starting and then the water in the heat exchanger is boiling and bubbling?0 -
Faulty Aquastat
It happens upon start up. During the cycle and when the cycle is done there is no noise. And it shuts off silently.0 -
Possible but doubtful...
When the copper fin tube boilers are fired without flow, they do what we in the industry call the "low mass dance". It makes your sphincter do the momba, and makes your feet want to run away from your body, all while your brain keeps chanting ****, ****…. And that doesn't stand for Wipe The Floor. The pressure gauge jumps ALL over the place, and the boiler literally jumps around vibrating. Unmistakeable.
But noises in general are not normal, so you might want to have a qualified technician give it a well boiler check and see if something is getting ready to cut loose. It does sound as though it could be a defective relay, or a defective ignition module who keeps trying for ignition.
Is it lit when it makes these sounds?
METhere was an error rendering this rich post.
I have not yet been able to get downstairs by the time it stops. And I have not been able to re-create the problem at the thermostat. My wife and kids tell me they hear banging in the pipes at night but by the time they wake me up nothing is happening. Just a normal sounding heat cycle.0 -
By the way...
Your pressure looks high. Could be you have a bad expansion tank, and the relief valve pops off, and by the time you get down there has reset itself, or… Could be a LOT of things.
Water on the floor is not normal. (Just sayin')
I presume other than noise your comfort levels are all OK?
Noises
The knocking may be a pipes rubbing on a framing member as it expands.The bubbling sound may mean air, and time to purge, but in your gauge picture, the pressure seems high.Purging without finding out why may cause the PRV to start discharging. Find out when the rest of the family, first started hearing the knocking. I usually find out everything that's wrong with the house "when the stove blows up", if you know what I mean?
The rapid clicking or buzzing is usually associated with a relay.The relay may be bad, or the transformer that provides the power for it, may be bad.0 -
comfort level
Yes, so far comfort levels are OK. It was -28C (-18.4F) last night. No water on the floor.0 -
Noises
Thanks. I do know what you mean about a catastrophe. That is why I am worried.
But did not want to call anyone out on Christmas Eve.
It is not pipe movement, we are familiar with that sound.
Is the pressure high for a 3 story old house? It has to push up 4 floors.
It does sound like a Relay to me also.
Thanks.0 -
Cold
It should probably be around 15 psi. Measure from regulator to highest point of radiation in feet, and multiply by .43.Then add 3 lbs to that.0 -
A couple of questions
Whats the psi rating thats stamped on your relief valve tag?
It could be a weak pump relay,transformer, or water logged expansion tank.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
