Pressuretrol High Limit control
cdm
Member Posts: 77
Steam system - Low pressure cut-in looks OK but high pressure cut-out is 2.25 psi (wheel is set at minimum 1 psi.) . Mains have 50% more venting than required. Any way to reset high set-point?
thanks -cd mulford-
thanks -cd mulford-
